How to mod dc2 coilovers to fit an EK?
Old Jan 15, 2003 | 03:34 PM
ichiba27's Avatar
ichiba27
Default How to mod dc2 coilovers to fit an EK?
I have a set of DC2 Cusco coilovers, I was wondering if I could install these on an ek? What mods would I need? I have SRR LCA's if that makes any difference.
Old Jan 15, 2003 | 09:04 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
USDM or JDM DC? For USDM, you just need some spacers to fill the void between the rear LCA's and the lower damper mounts because EK rear LCA's aren't as thick as EG/DC ones. If they're JDM DC2 coilovers, I don't tink you'll be able to use them since you would need to run JDM DC2 rear LCA's, and DC LCA's don't bolt on to EK's(they're too short, for one thing). The fronts will go right in. The SRR LCA's won't make a difference since they retain all the stock mounting points.
Old Jan 15, 2003 | 09:24 PM
ichiba27's Avatar
ichiba27
thanks, that cleared a lot of things up. Do you know if the shock lengths differ?
Old Jan 16, 2003 | 12:58 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Damper length between EG/DC and EK should be the same, unless it's a short-body coilover, which some are.
