headlight ??
Old Jan 10, 2003 | 07:17 PM
MoFo's Avatar
MoFo
Baddest mf'er...ever.
Default headlight ??
Ok, my driver side headlight is giving me crap. The low beam does not come on, but the high beam works fine.
It's not the bulb, I've tried a few brand new ones, and I get the same problem. I'm thinking fuse, anyone have some ideas?
Old Jan 10, 2003 | 08:33 PM
Tirod's Avatar
Tirod
probably fuse.. mine was.. i also know all the copper wiring in my harness attached to the bulb is all exposed.. previous owner installed projectors and i assume did a piss poor job.. so maybe something there?
Old Jan 10, 2003 | 08:45 PM
crucial Si's Avatar
crucial Si
Banned
check the fuse, the low beam and high beam run off different fuses for safety just in case on blows you still have both high beams or just one low beam
edit..
also you will notice if you have a blown fuse the clock doesnt dime down when you turn on the headlights....not neccessarily this but on some.
Old Jan 10, 2003 | 09:03 PM
b00gers's Avatar
b00gers
i didnt know that each headlight has its own fuse, ive always thought the pair has one.
somethings you can check, the harness, wires, fuse, or maybe even the handle thing that you turn.
Old Jan 10, 2003 | 09:19 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
first check the fuse,.if its not the fuse,..then its the harness,..this happened to me a couple months back,..a wire came off the harness and i had to kinda like take the harness apart to put the wire back in
Old Jan 11, 2003 | 05:23 AM
crucial Si's Avatar
crucial Si
Banned
each low beam has one along with the high beams. 4 fuses. its for safety. wiring it up most have been a bish though
