Reverse lights won't turn off Eg 5-speed
Old Feb 24, 2009 | 05:26 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Default Reverse lights won't turn off Eg 5-speed
So, my reverse lights want to stay on. The lights only turn off when I shift about halfway between neutral and reverse. I noticed my reverse cable on the tranny looks a little old, but before I replace it, anything else to look at? Everything else seems fine.
Old Feb 24, 2009 | 07:05 PM
A-series's Avatar
A-series
v-card member alpha
I'm assuming the switch is sticking, you can just disconnect the electrical connection at the trans. as a temporary fix. Otherwise I'd remove the switch and see if you can tell what's up, might have to replace it :shrug:
Old Feb 24, 2009 | 07:27 PM
Running925's Avatar
Running925
Your Powder Coater
agreed :thumbup:
Old Feb 24, 2009 | 07:49 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Werd. Thanks for the quick replies, guys. I guess I should just order a new one. It looks like a 16mm? bolt that holds the switch, so I'll just disconnect the wiring from the other end, so that I don't have a gaping hole in my tranny. o:
Old Feb 24, 2009 | 08:07 PM
Running925's Avatar
Running925
Your Powder Coater
just unplug the wire that comes off the sensor first! (test)
Old Feb 24, 2009 | 08:13 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Doing that will make it simply turn off, right? I'm moments away from ordering a new one with a bunch of other stuff. :hsugh:
Old Feb 25, 2009 | 05:09 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Disconnecting the wire should make the the reverse light turn off. Are they on with the key on, key off, or both? If they are on with the key off then there is going to be a short someplace.
Old Feb 25, 2009 | 08:52 AM
cruzalekz's Avatar
cruzalekz
or just re wire it and make a switch to your dash.
or just remove the bulbs or maybe just put strobes lol
Old Feb 25, 2009 | 11:45 AM
Chefboiali's Avatar
Chefboiali
scrotal surge
They only come on when I turn the car on. The only time they turn off is when I turn the car off, or when I'm half way between reverse and neutral.
Old Feb 25, 2009 | 02:52 PM
cruzalekz's Avatar
cruzalekz
that makes it more easier, just cut the wire and put a switch in between it.
