Spark Plugs and wires
Old Jan 7, 2003 | 07:03 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
NGK is what Honda uses so stick to them. The blue ones aren't stock, they are better, I think they are larger so there is less resistance and they also have magnetic parts and some crap like that. Regular Copper NGK plugs are also the best.
Old Jan 7, 2003 | 07:17 PM
Crash&Burn's Avatar
Crash&Burn
I use Bosch Platnum Plug.
Old Jan 7, 2003 | 10:17 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
NGK Vpower copper plugs - $2 a pop
NGK blue plug wires (came stock on my 5th gen) - $30-40
No need to spend any more.
Old Jan 7, 2003 | 10:21 PM
Kai's Avatar
Kai
Rotorphile.
Well, you have to understand that my NKG plugs are special plugs, 'cause rotary engines are super-extra neato enough to justify funky plugs that cost out the ass. Only two companies even make the things. Have any of you guys ever seen a rotary engine spark plug? Pure insanity, but they work and work well.
For some interesting reading on Magnecor wires, try http://www.magnecor.com I like my 8.5mm wires. The only difference between the 8.5mm and 10mm is the thickness of the insulation. Plus they are a pretty red:thumbup:
Old Jan 7, 2003 | 10:27 PM
shonnys92si's Avatar
shonnys92si
i bought denzo iridium, but my next set of plugs are going to be ngk lucky 7. check www.ngk.com use stock wires
Old Jan 8, 2003 | 04:45 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
thanks alot. I thought that the NGK blues came with the car.
Old Jan 8, 2003 | 06:10 AM
CivicEXR99's Avatar
CivicEXR99
Vladamirious
Stick with NGK like said above. It's what comes stock on Honda. I like NGK.
