02tls hid's drop into 00 ex?
does the stock 02tls hid setup drop right into the 00 ex H4 setup? I'm going to pick up a set tomorrow and i wanted to know for sure.
this should help you out... http://forums.clubsi.com/showflat.ph...ue#Post1197128
Just let you know that you'll blind oncoming traffic... :( |
Originally posted by DIESEL8118 this should help you out... http://forums.clubsi.com/showflat.ph...ue#Post1197128 Just let you know that you'll blind oncoming traffic... :( so basically i'll need to modify the housing for it to accept the bulb? |
Originally posted by Jkan2001 so basically i'll need to modify the housing for it to accept the bulb? As for the housing, you can do nothing about it. Our Civic headlight housings are designed for halogen bulbs. You can build a shield for the bulb to reduce glare. also check out http://faq.auto.light.tripod.com/special-topics.htm for more info. HTH :) |
Originally posted by DIESEL8118 to get the HID bulbs (I assume D2R) fit, you'll have to pull your stock or aftermarket H4 rings out, and then glue them to the HID bulbs. As for the housing, you can do nothing about it. Our Civic headlight housings are designed for halogen bulbs. You can build a shield for the bulb to reduce glare. also check out http://faq.auto.light.tripod.com/special-topics.htm for more info. HTH :) hrmmm i don't know about the whole pulling the h4 ring out and glueing it to the bulb :confused: doesn't sound too safe |
Originally posted by Jkan2001 hrmmm i don't know about the whole pulling the h4 ring out and glueing it to the bulb :confused: doesn't sound too safe Another option is to get this... http://www.casperselectronics.com/cg...s/103016-1.jpg http://www.casperselectronics.com/cg...e/commerce.cgi product # 103016 |
Why not just find an HID system which incorporates a projector unit and retro fit the projector unit into your headlamp housing? I think that would eliminate glare and give you the light output and correct beam pattern. Plus it would be cool to have some Audi or Bimmer projectors:naughty:
Mike |
Originally posted by Mike Why not just find an HID system which incorporates a projector unit and retro fit the projector unit into your headlamp housing? I think that would eliminate glare and give you the light output and correct beam pattern. Plus it would be cool to have some Audi or Bimmer projectors:naughty: Mike |
Originally posted by Mike Why not just find an HID system which incorporates a projector unit and retro fit the projector unit into your headlamp housing? I think that would eliminate glare and give you the light output and correct beam pattern. Plus it would be cool to have some Audi or Bimmer projectors:naughty: Mike :thumbup: i really don't want to take the time to take out my headlights, cut them open, work on them etc etc. I'm just asking cause i found a great deal on some 02 tls headlights with new D2R bulbs and i thought i'd get them if they drop in easily. also i read on that casper electronic site, it says it's for D2S to H4 but i think the TLS had D2R, is there a difference? |
Originally posted by Jkan2001 1 simple word...lazy :thumbup: i really don't want to take the time to take out my headlights, cut them open, work on them etc etc. I'm just asking cause i found a great deal on some 02 tls headlights with new D2R bulbs and i thought i'd get them if they drop in easily. also i read on that casper electronic site, it says it's for D2S to H4 but i think the TLS had D2R, is there a difference? But hey do what u want :fawk: As to your bulb question, I'm not sure...I'll try and find out for you though. Mike |
| All times are GMT -8. The time now is 01:40 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
