Questions about installing beaks kit??
Okay, I have my teg LCA's with poly bushings ready to install.
It'll be a few weeks before I get my beaks kit w/ ITR swaybar. My question is, do the lca's have to be off to install the beaks kit? If not, I want to go ahead and install the teg LCA's to have that much done.
Thanks.
Thanks.
no you do not take the lca's off when installing beaks kit.
you will need to disconnet the lca's from the subframe (middle part under the car), so you can slide the beaks kit inside the subframe, and bolt the outer piece/d bracket all together.
beaks kit is great. i got my friend the whole combo for xmas.
Originally posted by skubb
so with the beaks kit, I don't have to have si lcas? how much do they run?
http://beaksproducts.com/srk-ek.html
