Headlights
Old Nov 7, 2008 | 06:51 PM
HECTIC_1's Avatar
HECTIC_1
Default Headlights
Ok! I posted about my headlights awhile back that they were blinking then they finally went out so I tried new ones but still nothing. I did a little bit of research and I'm thinking that it might be a headlight switch?????? I checked the wiring and it seems fine all the fuses. Any one have any suggestions?
Old Nov 7, 2008 | 07:09 PM
Fuse's Avatar
Fuse
You can read up on this. How to use and etm.
http://www.talkjdm.com/showthread.php?t=3307
Do some voltage test and you should be able to find the problem.
Old Nov 7, 2008 | 10:34 PM
HECTIC_1's Avatar
HECTIC_1
Well check it out, I was in my car and was messin with headlight switch and my headlights turned on, but I turned them off and tried to turn them back on and they didnt come on so I think the switch is bad.
