compression of sol b16a
Old Dec 16, 2002 | 04:04 PM
solRNY's Avatar
solRNY
Default compression of sol b16a
hey,
i gonna do a compression test and was wondering what is the nominal compression for a b16a delsol? thanks
Old Dec 16, 2002 | 07:45 PM
societyslave's Avatar
societyslave
want me to pierce what?
i believe that the comp. ratio should be 10.5.1
Old Dec 17, 2002 | 09:24 AM
solRNY's Avatar
solRNY
thanks, but i am going ot use a compression test kit that will show it in PSI, what does that mean in PSI? wht is the nominal PSI in each cylinder? thanks u much
Old Dec 17, 2002 | 12:18 PM
crucial Si's Avatar
crucial Si
Banned
its 10.2
Old Dec 17, 2002 | 12:40 PM
Soltaker's Avatar
Soltaker
I'm a bad, bad man.
It should be around 200 psi. In fact, each cylinder should be within 5% of each other across the board.
Old Dec 17, 2002 | 01:17 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I want to say 195, but I can check the manual later. I'm home from work, sick with the flu, so I have nothing better to do...
Old Dec 20, 2002 | 04:27 AM
solRNY's Avatar
solRNY
thans, i will test it out after xmas,
