vtec diy questions
Old Dec 13, 2002 | 11:57 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default vtec diy questions
i've seen the easy mod on jdmfan.com on how to install a vtec light. my question is... where would u mount the light? is there like a place where u have to drill out to put the light? thanks
Old Dec 14, 2002 | 12:07 AM
SloVx's Avatar
SloVx
im pretty sure its up to you where you want the light just run the wires long enuff to where you wanted the light to be mounted
Old Dec 14, 2002 | 12:09 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
i know how to run the wire... but it's more of where the light would be mounted that i am wondering about.
Old Dec 14, 2002 | 03:11 PM
Snoopy's Avatar
Snoopy
been there done that
like he said its all up to you. use your imagination!
Old Dec 14, 2002 | 05:50 PM
jordan88's Avatar
jordan88
can you give me the instructions how to install and run the wire on a 98 civic ex?
thanks you!!
Old Dec 15, 2002 | 11:25 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
thanks you!!
http://www.jdmfan.com/technical/cosm...tec_indicator/
i just followed the instructions from here. the installation is the same for your 98. just make sure the engine has vtec.
Old Dec 16, 2002 | 06:27 PM
spooncivicb16b's Avatar
spooncivicb16b
did it last night toook like 20 min. i used a little blue led its really bright
Old Dec 17, 2002 | 07:32 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
where did u tap ur line into? did u tap it into the ECU or directly onto the solernoid? if directly into the solernoid... how did u run the line from the engine bay into the cluster?
Old Dec 18, 2002 | 02:10 PM
spooncivicb16b
i just tapped into the solinoid ran the wire in the car and i dont know abou ex's but my si has an open spot that doesn't have a light or anything right above 5k rpm thats where i put it
