1993 honda civic axle
hello,
I was wondering if anyone can help me out. My axle poped out of my tranny as i was driving my car is drop someone told me it was probaly cause i hit somthing hard. Well n-e-ways im trying to but the axle back and it seems it dosent want to lock good. The axle locks but if i pull the axle towards me with a lil pressure it comes loose. My question is, IS this normal? if not what can i do.
Help
Help
From what I understand they pull out fairly easily. I would put it back in anf make sure it locks in. If it comes out again the only thing you can do is buy a new axle. They aren't to expensive they run about $80.
Remove the axel and examine it to make sure the joints are not lock/sieze first. If good, reinstall. There is a excellent how to in the How-To forum for axel replacement.
Check the condition of the lock ring if there is one at the end of the shaft that inserts into the tranny. If it's damaged then just replace it with a new ring. Oh and make sure the ring faces downward when installing it.
Your Powder Coater
this is the correct answer. There is no reason to replace the axle over this. The lock ring is the issue here.
I but the axle back ( i did not change the lock ring) and it came loose again. I checked the lock ring and it looks ok do you guys think its the ring even though it look ok should i still change
I push the axle in and it seem it locks a go under the car and the axle is really close to the tranny wall. But if i push it towards me a with a little pressure it comes loose
