Clutch problem
Old Dec 11, 2002 | 05:16 AM
BrainFearGone's Avatar
BrainFearGone
Default Clutch problem
I jumped in my 93 si yesterday...put in the clutch and it went to the floor...no pressure or ne thing...so i started it and it caught at the bottom instead of the usual spot....i added fluid to the resivoir...it was low...then i waited and started it it again...it was still ****ed...so i figured i had air in the line so i needed to bleed it...i did that and after adding some fluid to the brake resivoir and the other..the pressure seamed to come back to normal and the air seems to be gone...any one have any sugestions on if i was checkin the right thing and should it be back to normal now?..thanks
Old Dec 11, 2002 | 08:49 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If there was air in the clutch line, and you bled it via the slave cylinder, than it should be fine
Old Dec 11, 2002 | 08:53 AM
Outxider's Avatar
Outxider
X-Motoring
