Programming new keyless entry remote
Old Dec 9, 2002 | 05:38 AM
CivicPete's Avatar
CivicPete
Default Programming new keyless entry remote
Hey guys..... Heres a question that has been stumping me for about a week now. I purchased a new Honda Keyless remote for my 98 ex the other day. i thouhgt it would be a quick programming like in the manuel but it just wont work... the new transmitter has the same FCC ID as the old one. I just dont want to go to the honda dealership for something like this.... If someone could post the instructions or what i should do it would be greatly appreicated. THanks alot guys! :thumbup:
Old Dec 10, 2002 | 07:42 AM
CivicPete's Avatar
CivicPete
Anyone?
Old Dec 10, 2002 | 08:37 AM
str8edgexx's Avatar
str8edgexx
I did a little search for you before, but couldn't find anything....only thing I found said that you need to turn the car on and off holding the lock button on the remote. Let me keep trying.
Old Dec 10, 2002 | 02:08 PM
CivicPete's Avatar
CivicPete
thanks man.... it is greatly appreicated....
Old Dec 10, 2002 | 03:55 PM
str8edgexx's Avatar
str8edgexx
Ok....after a little investigation, I've found this. It says its for '99-'00, but chances are it should work. Give it a shot, and if it doesn't work, I'll keep looking. Let me know how it works out, ok? Thanks
Keyless Entry Instructions
Old Dec 10, 2002 | 07:06 PM
CivicPete's Avatar
CivicPete
I just tryed it and nothing i tryed it like 10 times.... thanks man for lookin that **** up!
Old Dec 11, 2002 | 03:37 AM
str8edgexx's Avatar
str8edgexx
hmmm....that kind of sucks. Any idea how much it would cost to just have the dealership do it? I know how badly they rip people off, but if they say they'll do it for like $10 or so, it'll be worth it. They might even do it for free. After I got my Viper alarm installed, I got an extra remote for it off of Ebay, and took it back to the place that did the install for me, and they programed it for free...even though I didn't buy it from them. If I were you, I'd make a few calls...call a couple of dealerships around you, and see what kind of prices you're getting.
Old Aug 19, 2003 | 12:04 PM
crohnieboy's Avatar
crohnieboy
Default programming a remote
Try this:
http://www.handaaccessories.com/civic98.html
HTH
Old Apr 18, 2004 | 02:32 PM
wd_b's Avatar
wd_b
Default 2000 Acura 1.6 EL keyless reprogram...
I just successfully reprogrammed the keyless remotes for my 1.6 EL using the instructions found at http://www.handa-accessories.com/crv/KEYLESSPROG.PDF - it worked like a charm. Thanks!
Old Apr 19, 2004 | 12:49 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
do you still have the OEM radio installed? Or do you have an aftermarket headunit in place?
96-98 civics have the keyless system built into the factory deck, so if you don't have it, there's your problem.
if you do, then either the remote is dead (not so likely), or the harness for the keyless system isn't plugged in. Other than that, there could be other problems, but who knows what it could be.....
but yeah, you do the whole turning the ignition 3 times, pressing the lock button each time, and all that. Make sure you're doing it quick enough, since you need to do it in under 5 or 10 seconds each time. But it works. I had to deal with all this when I installed my dads OEM keyless system into his accord.
