things to note when installing a turbo...
make sure you teflon tape the threads for the oil feed....i have the APEX kit on my 00ex and the guy that had the kit before me forgot to teflon tape it. I didn't think to even check it and after i installed the whole kit i started it up and it LEAKED OIL so i had to take it all off and basically reinstall the whole kit.
Originally posted by yellow civic ex
thanks, that site will be really helpful. one more question...is turbo magazines website usually a reliable source of info?? they said that the apexi kit with the gt intercooler at only 5lbs of boost makes 187whp...i'm not sure how accurate that is, since i know kits like greddy only give a sohc like 140whp. check out this site:
http://www.turbomagazine.com/tech/0108tur_apexturbo/
Originally posted by inspyral
They tuned the A'PEXi kit with an AFC. The numbers you're thinking of for the GReddy kit are probably untuned. The GReddy kit is also a good option for SOHC boost, but it may take more boost pressure to make the same power. You can easilly get past the 200hp mark with a GReddy kit, but t will take some good tuning with a standalone unit, and at about 8-12lbs of boost to do it.
Originally posted by derf
how do you tune a turbo?... can you explain? never really understood that..... what are you able tp change... besides. boost
Originally posted by tokyoracer
so does this mean the the apexi will make more power with a smaller lbs of boost when compared to the greddy kit? since the apexi is ball bearing.. so i am assuming that it'll spool faster than then greddy? is that correct?
air fuel controller = AFC rite?
