Bump noise from the back
Old Dec 3, 2002 | 04:23 AM
TwilightX's Avatar
TwilightX
Nope - pretty much clean in the back...well, aside from the spare, and a set of tools/jumper cables...
Old Dec 3, 2002 | 09:26 AM
derf's Avatar
derf
Spec5
you might have knocked you exhaust loose? if it came off one of the hangers or something it might be knocking around... just look into it... anything metal basically.
Old Dec 3, 2002 | 09:32 AM
TwilightX's Avatar
TwilightX
Interesting...I'll have to check that tonight and see if that's a possibility...last time I was under the car, it seemed pretty stable - the only other rattle I hear is when the car is starting up and the stupid heat shield vibrates...
Old Dec 3, 2002 | 09:34 AM
derf's Avatar
derf
Spec5
i just figured if u were turning... maybe the exhaust is hitting the ground or something... just look around and see if anything is loose. i personally have never had a blown shock so i can't tell u about that... but my exhaust has definiately knocked around only on certain turns.
