Dropping the pimpmobile (lol)...
i'd get some Ground Controls coilovers and get some integra spring rates or even custom rates. why? because the stiffer rate will prevent some sloping when you have passengers in the back, plus you can adjust to the correct desired height.
ok thats the ground control adjustables.
theres the springs, the sleeve (red thing with threads), and the perch (i think its called) which is the gold thing.
the springs sit ontop of the perch. you can turn the perch like a nut on a bolt, to make it go up or down. after you get the desired height, just lock the perch with a allen screw.
:dunno:
