exterior door handle
Old Aug 10, 2008 | 07:51 AM
erinrae440's Avatar
erinrae440
Default exterior door handle
Please help me. My door handle snapped off last night, I ordered a replacement, and have no idea on how to install it. Can someone please instruct me on how to, and atleast guide me in the right direction.
I have a 95 Honda Civic EX.
I would appreciate it. Thanks!
Old Aug 11, 2008 | 06:08 AM
MeanGreen's Avatar
MeanGreen
ive had to do this at least 3 times in the last 4 years or so...
hmm.. if i can remember correctly.. get your flashlight out....
first take off your door panel.
then you need to pull back the plastic near the handle.
i believe theres like two 10mm bolts and you undo those, and pop out the 1inch e-clip on the back side of the key lock... it holds the lock part onto the door metal - use a pair of needle nose plyiers for that.
Then you got to turn the handle so that the hard metal line comes out, that line goes into a little plastic yellow bit that keeps the metal wire snapped onto the handle. The eclip also holds the lock inplace on the handle. switch the lock into the new handle.
sorry that a little vague, its been a lil while since i did mine last, id have to look at mine again, but its pretty simple.
one thing though. that little yellow bit that pops into the new handle where the hard metal line goes into, make sure you use the new one that comes with the new handle or the lock hard line will more than likely pop out when you get it all back together.
do not force it!!!! if its not coming out, do not try to pry it out. check your work again. also when putting the new one on, dont over turn the bolts because you can strip out your new handles reciever nuts (embedded in the plastic) and that would suck. just make it snug, not more than 7lbs probably.when you got it hand tight, dont turn them anymore. if the old handle's bolts are spun out then drill from the out side, i had to do that once.
and with the new handles, be gentle wit dem. They obviously break easily.
Old Aug 12, 2008 | 08:30 PM
A-series's Avatar
A-series
v-card member alpha
Good idea to apply lube, I prefer gel lube (or a grease) as opposed to wd40 which doesn't last as long, the mechanism on the back of the exterior handle. If you keep that working smoothly, you shouldn't have to worry about it breaking/working itself out.
Once you get the inner door panel off, you'll be able to figure it out. Be careful with the pastic inside, pull it back gently enough and you can put it back (sometimes even without apply new sealant). I ripped mine the first time I had to do it.
Old Aug 12, 2008 | 08:55 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
... as opposed to wd40 which doesn't last as long ...
Say it with me, kids:
WD40 is a solvent.... not a lubricant.
:shake:
Old Aug 12, 2008 | 10:04 PM
A-series's Avatar
A-series
v-card member alpha
^ I used it on the old mechanisms to penetrate and free them up, followed up with the gel lube(which by itself made no difference to the old, corroded shit). On the new one that I just put on, I only applied gel lube.
Lots of people though, at least many that I know, will just keep spraying WD 40 on things like their door hinges over and over again - better than nothing but you're right.
