Cluth problems (pretty sure)
Old Nov 20, 2002 | 01:29 PM
Mr BoJangles's Avatar
Mr BoJangles
Default Cluth problems (pretty sure)
I just put the d16 in my 94 dx, and everything is running perfect. Except when I let out on the clutch, nothing happens, just keeps idaling like I am in neutral.
All I can think of is that the clutch that came with the swap is completely blown. Any other ideas before I tear the tranny apart replacing the clutch?
The salvage yard that I got the swap from was kind enough to give me another clutch assebly with low miles, after many many calls. The engine has about 65,000 miles on it, so do I need to resurface the flywheel at the same time or should it be allright?
Thanks for any help. Also any ideas...
-CS
Old Nov 20, 2002 | 02:11 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I hate to have to ask, but did you bleed the clutch line? Or has the slave cylinder popped off the arm?
Old Nov 20, 2002 | 02:30 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly what I was thinking... bleed that clutch!
Old Nov 20, 2002 | 07:35 PM
Mr BoJangles
Yeah, don't worry, not a complete moron
however I am sure five other people reading this post just figured out what was wrong with their clutch
Any other ideas?
Old Nov 21, 2002 | 02:01 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Well, if you have pedal pressure and the shifter is going into gears, I'd say your disc is shot.
Old Nov 21, 2002 | 02:46 AM
westcoaststyle
Are you absolutely sure that the slave cylinder arm is correctly installed into the shift fork?
Otherwise, I'd also say your disk is shot...
