How much oil 93 civic dx
Old Jul 6, 2008 | 02:50 AM
toosoonjr's Avatar
toosoonjr
Default How much oil 93 civic dx
How much oil is needed in the stock 1.5 motor and what oil thickness should I be using in a car with 200+k miles. I tried searching but oil+how didn't pull up any useful threads.
Thanks!
Old Jul 6, 2008 | 06:16 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
There is a sticker under your hood that lists info like this. If it's missing, check the manual. I'll give you a little hint though, if you keep adding oil and checking your dipstick, I bet you'll end up with the right amount....
Old Jul 7, 2008 | 01:22 AM
remy's Avatar
remy
most hondas take between 3-4 quarts!!
but just do like Bakeoff said....that is what you have the dipstick for!!
Old Jul 8, 2008 | 04:57 PM
thetunersource's Avatar
thetunersource
i think on that particular model its about 3.75 but use your dipstick, you dipstick haha jk!
Old Jul 8, 2008 | 06:53 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I always just threw in 4 quarts, standard operating procedure for B & D series.
Old Jul 9, 2008 | 01:46 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yup. 5w-30. I found that I stopped burning oil in the Integra when I started putting in 10w-40.
Old Jul 9, 2008 | 02:04 PM
fourormore's Avatar
fourormore
Always use the dipstick, with 200k on it who knows what kind of goop is in the pan or anywhere else for that matter.
Old Jul 12, 2008 | 08:30 PM
A-series's Avatar
A-series
v-card member alpha
Should be around 3.5 as that's what the 1.6L from that year uses. I'd use 5w30, what's recommended, unless you're burning a lot of oil - even then, I'd suggest an oil w/ seal conditioner first before going thicker.
Old Jul 13, 2008 | 01:21 PM
thetunersource
if you have more than 80000 miles goto 10w dont use 5w
Old Jul 13, 2008 | 04:40 PM
Jafro's Avatar
Jafro
I'm made of meat!
+ 1
