Frankinstein Engine vs B18c
Old Nov 17, 2002 | 10:19 PM
ImportRac3r's Avatar
ImportRac3r
Elite Member
Default Frankinstein Engine vs B18c
For some time lately I've been finding a little bit more interest in these B20 vtecs (prices???). Now what I have been set on and saving up for has been the B18c1 but lately I keep reading more and more good stuff about this engine....For those that have a broad knowledge of these two engines, (say there both fully built with pistons, rods, turbo cams, valves, port and polish, and of course the T3/T4 turbo,...etc..) which one pound for pound is going to be better? Oh and another question I cant find is which head would you put on the B20?
Old Nov 17, 2002 | 11:13 PM
DSC's Avatar
DSC
Long way from home
There is no replacement for displacement.
But if you dont build it right it'll blow up.
Stick with the B18
Old Nov 18, 2002 | 12:04 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Originally posted by inspyral
If your definition of "fully built" includes new sleeves, I would go with the B18C1, hands down. You can take a B18C1, sleeve it to 84mm, put an LS crank and LS rods in it, and you'll have the displacement of a B20, plus VTEC with OEM block girdle, VTEC oiling components, and OEM reliability. A B18C1 resleeved to 84mm would also be a lot stronger than stock B20 sleeves. If you're trying to boost on stock B20 sleeves, you can't run all that much boost before structural integrity becomes an issue. The B20 sleeves are one-piece and at a glance would seem more sturdy than the induvidual B18 sleeves, but the areas between the cylinders on the B20 sleeves are the weak points. This would lead one to conclude that, in order to run anything beyond moderate boost on a B20 block, it is necessary to have it resleeved. If you're going to be getting new sleeves anyway, why not just sleeve a B18C1 to 84mm and have all the VTEC components as they came from the factory, rather than trying to add them to a B20 block.
Old Nov 18, 2002 | 04:50 AM
ManTiS's Avatar
ManTiS
NinJA
Stock sleeves in a b18c1 are strong. Enough to propel a local drag racer to high 10s in a turbo GSR hatchback
