bulb or headlight prob?
Old Nov 17, 2002 | 07:03 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You may want to check the grounds for each headlight. One may not be getting the ground it needs. That's where I would start.
Old Nov 17, 2002 | 11:13 AM
NewbieCivic's Avatar
NewbieCivic
alright..i didnt touch the bulbs i kno that for a fact...i used rubber gloves but then again i didnt touch em...but how do i check? im new to this i dont kno where to start?
Old Nov 18, 2002 | 08:00 AM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
Originally posted by derf
I personally don't think the grease is a problem..... if you read your manual you would have found out that you can lift the power steering resevoir UP and out of the way to change the front left bulb
Lifting it up was useless for me. It was almost just as tight as when its locked in place... I felt that I was going to rip the hoses off if I lifted it any higher.
BLAH!
Old Nov 18, 2002 | 09:07 AM
Nelson's Avatar
Nelson
Administrator
You might want to try adjusting the level of the light, it might be that it's not aimed correctly and giving you that sense of dfferent lighting.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
