Difference between SOHC VTEC & DOHC VTEC ???
Old Nov 16, 2002 | 10:03 PM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
You can feel IT in the dohc.
Old Nov 17, 2002 | 08:47 AM
crucial Si's Avatar
crucial Si
Banned
feel what the x over? i feel it in mine.... another usesless opinion.
Old Nov 17, 2002 | 11:58 AM
br0nx finest's Avatar
br0nx finest
I drive a cb7, y0.
:thumbup:
Originally posted by HappySnatch
your friend is a dumbass
wned:
Old Nov 18, 2002 | 07:35 AM
supapoopa's Avatar
supapoopa
Well then you are feeling priieetty HARD to feel that.
your useless opinion of my useless opinion...
is useless. :fawk:
Old Nov 18, 2002 | 10:03 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
that's not true....what if you drive a b20 or a LS :fawk:
besides B series powered cars are slow for the most part unless they have serious n/a work or FI. I can put around 3-4 on a GSR if i wind it out, about 6 on a civic SI or B16 swapped car. In fact a edged out a turbo SI today so :madfawk: DOHC's
BlackWidowCivic's Avatar
BlackWidowCivic
yea i heard that if you were plannin to install a turbo kit than the SOHC would be a better choice, i have a SOHC and i hate it, thats why i am goin with the b16a with a turbo kit, i jus dont which one i want, any suggestions would help out alot
Old Nov 18, 2002 | 10:04 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
there was a 6th gen si w/ a bodykit and 17 axxis seven rims at the track last night on a greddy turbo kit w/ fmic...he ran 15.4 constaint times....fawking pathetic.
bwahahahah that's probably the guy i raced today! 6 gen si w/a body kit some 17" rims the greddy turbo kit and a FMIC...he was slower than me. :ghey:
Old Nov 18, 2002 | 10:41 AM
supapoopa's Avatar
supapoopa
DOH!!:fawk:
You can feel IT* in the dohc**.
* vtec crossover
**vtec equipped
Forgot the fine print at the bottom
Old Jan 28, 2003 | 02:56 PM
Nori's Avatar
Nori
Originally posted by upgraded Si
not really..comparing the d16 to b16...they rate the single cam only having 107 lb/tq and the dualcam at 111 lb/tq...which ive read that to the ground the single cam puts out the same or more to the ground.
true to that
Old Jan 28, 2003 | 03:38 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
There is actually a very large difference between the two. The SOHC VTEC only has the variable affect on the intake side (there is only so much room on a camshaft). A DOHC VTEC has VTEC on both the intake and exhaust cams. The DOHC does, has a bit of an advantage because of this, but is also much more expensive (a lot more parts to support and contol that second cam), heavier (ditto) and as far as I knew, made less torque (it takes more engine effort to turn two cams) but I'm not positive on that part.
Also, another big difference is the fact that Honda builds the SOHC to be lower performance engines. The SOHC engines (even the VTEC one's) are found in lower model Civic's and the DOHC VTEC engines are found in the upper level Civic's and Integra's. If Honda were to build a SOHC VTEC engine with the same high compression, aggressive cam and fuel tuning to support 8000 rpm and a similiarly geared tranny to a DOHC VTEC, the SOHC would most likely match the DOHC's numbers. Problem is Honda doesn't do that. They're more concerned with emissions and milage with most SOHC engines because there put in cars that are sold to people (for the most part) who are less concerned with performance and more interested in mileage and reliablity.
By the way, just so you know, Corvette's don't use DOHC engines, they still use pushrods engines. The SVT Mustang Cobra is a 5.4L DOHC engine and it is impressive. Seeya.
