condensor hoses - does coolant run thru them?
Old Jun 24, 2008 | 06:24 AM
snosurfa7's Avatar
snosurfa7
Default condensor hoses - does coolant run thru them?
Does radiator fluid flow through the front condensor hose (the one with a "H" on the blue cap)?
b/c I have a radiator leak and the area where you have metal on rubber on that hose seems to be seeping radiator fluid...
thanks!
Old Jun 24, 2008 | 06:30 AM
mattc28's Avatar
mattc28
Your condenser does not have coolant in it, it has refridgerant, which is mostly a gas. The "H" stands for high pressure. There are 2 condenser hoses, one for high pressure and one for low.
Old Jun 24, 2008 | 06:39 AM
snosurfa7's Avatar
snosurfa7
Ok thanks makes sense. Just have some greenish coolant-like stuff (even smells like it) collecting around that hose and a small (1" drop) in my radiator fluid level. weird.
Old Jun 24, 2008 | 06:41 AM
mattc28's Avatar
mattc28
Does your AC work well? Sometimes, when you recharge your AC, and your condenser has a leak, they put "stop leak" stuff into it. It could leak just a little, it looks like green bubbly slime.
Old Jun 25, 2008 | 06:29 AM
snosurfa7's Avatar
snosurfa7
Hmmm it does look a little like green bubbly slime...but if definitely smells like coolant. the a/c actually works very well, never recharged it in the 2 years and 40K I've owned the car.
I think I'll just swap a new radiator in anyway, at 263K on the original its gotta be time if not now then very soon.
thanks
