bad syncro?
Old Nov 16, 2002 | 05:02 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by inspyral
I assume that's straight motor oil? Motor oil can be used as a temporary substitute for MTF in manual Honda transaxles, but should be changed out for MTF as soon as possible. Motor oil lacks the conditioners that, amoung other things, keep synchros alive and well. Honda MTF is like $3 a quart, and you only need (less than)3 quarts every 30k miles or so. I would not skimp on MTF.
Good call. That's exactly what I was going to say.
Old Nov 16, 2002 | 01:35 PM
crucial Si's Avatar
crucial Si
Banned
what about gear oil? like a 70 weight?
Old Nov 16, 2002 | 01:59 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i beilieve you'll need 2.2 quarts of the motor oil.
a way to check to see if you have enough oil in your tranny is to put you finger in the filler hole and feel for the oil. you should feel oil on the base of your finger.
you are also suppose to have your car level when putting tranny fluid in. so have all 4 sides jacked up when putting mtf in.
and yes i'd only use Honda Tranny fluid in inspyral said.
also next time you shift into gear, have the clutch pedall the way down and keep it down and then put the shifter into gear to see if maybe your clutch is the issue which i doubt it is.
I'd get Honda MTF asap.
Project EVA - The Track Package
Project EVA
Old Nov 16, 2002 | 02:07 PM
crucial Si's Avatar
crucial Si
Banned
the car was level. yeah, it takes around 2.2-2.4 qts...once it starts spilling out the side thats how i know its full. when i have the clutch all the way down it still does it.
Old Nov 16, 2002 | 03:18 PM
Luis's Avatar
Luis
Civic1.6VTEC
Mike, just get a new car...... :fawk:
Old Nov 16, 2002 | 08:12 PM
crucial Si's Avatar
crucial Si
Banned
your the one w/ the '95 w/ almost 200K miles on the biitch:fawk:
