Cigerette lighter questin
Old Nov 14, 2002 | 08:18 AM
Xqu1sit's Avatar
Xqu1sit
Default Cigerette lighter questin
Hey my cigerette lighter broke so i want to disconnected it and get a new one.. the only problem is i don't know how to disconnect it, can any one help?
Old Nov 14, 2002 | 08:25 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
what year car?
Old Nov 14, 2002 | 08:43 AM
str8edgexx's Avatar
str8edgexx
on my 6th gen, you just need to remove the wire harness off the back of it and then you can just take it out.
Old Nov 14, 2002 | 09:03 AM
westcoaststyle
on the 5th gen, you remove the screw on either side of the center console and the 2 the screw into it at the top (vertically)
The console comes out top first and there is a little connector that just plugs into the lighter. Remove that and you're good.
Old Nov 14, 2002 | 09:22 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
thanks for the helpful details, it sure will be easy to tell you how to take apart your car.
Old Nov 15, 2002 | 06:29 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default Re: Cigerette lighter questin
r u sure the cig lighter plug is broken? u might want to check out the fuse for that one before doing so. my friend had the same problem and as it turned out... it was the fuse not the plug. unless if you see black burnt marks on the inside of the white stone lookalike.. u don't need to change it.
