throttle body ?
Old Nov 13, 2002 | 08:35 PM
caneoner's Avatar
caneoner
Default throttle body ?
my girlfriend just crashed her 87 crx si i have a 91 dx hb and i am swapping the intake maniold with one from a 91 si. i still need a throttle position sensor which i can't seem to find. can i take her throttle body off her car and put it on my 91 si hb manifold that way i can splice her throttle position sensor into my wiring.
Old Nov 13, 2002 | 11:59 PM
92b16vx's Avatar
92b16vx
I had a 1st gen rex si and I believe your dx throttle body is to small but if it bolts up try it the worst thing that will happen is it won't fit.
Old Nov 14, 2002 | 05:32 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
you can probably use the TPS sensor off of her TB.
Project EVA - The Track Package
Project EVA
Old Nov 14, 2002 | 07:38 AM
Kai's Avatar
Kai
Rotorphile.
I really doubt it. The 85-87 CRX Si and 86-87 Civic Si used a throttle body that has a strange bolt pattern, and a plastic spacer. If it does fit, I would be very suprised.
Edit:
This is what I'm talking about, this is from my Si.
Old Nov 14, 2002 | 12:53 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Edit:
your MAP sensor isn't conected!
edit: n/m, looks like that vac hose goes to a tee that point sdown on the other side...h:
Old Nov 14, 2002 | 01:50 PM
Kai's Avatar
Kai
Rotorphile.
You had me worried there for a minute! The MAP better be connected, I just replaced it's vac line, but you can only see a wee bit in that pic A disconnected MAP would still be the least of this thing's problems, though
Old Nov 14, 2002 | 02:00 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
so is the tps different?
i know d and b series from 92+ use the same tps.
Project EVA
