Cams, cam gears and valvtrain questions
Old Nov 13, 2002 | 06:42 AM
blkvtecsi99's Avatar
blkvtecsi99
Default Cams, cam gears and valvtrain questions
Hey everyone I have a few questions and I need some opinions. I am going to be buying cams, cam gears and valvesprings and retainers for my b16a2. I was thinking about going with the ctr intake cam and the itr exhaust cam. For the cam gears I am looking into jun, toda, and skunk2. Springs and retainers I am looking at jun. My ride is a daily driver so I need to keep it that way. Are there any concerns or conflicts I might have if I use a combo of the components and brands listed? Any info will help. Thanks
Old Nov 13, 2002 | 06:49 AM
dnt94civic's Avatar
dnt94civic
There shouldn't be any problems with this setup, but why are you going to buy the springs and retainers when you don't need them. The ITR/CTR cams can be used with your stock springs and retainers. The only reason I can see for using them, is if you were going to raise your rev limit to 9000 or more. But since you said this would be your daily driver I don't see that happening. instead of the springs and retainers, I would just buy the Apexi VAFC and get some dyno tuning done to max out the power.
well, that just my opinion anyways
Old Nov 13, 2002 | 12:36 PM
blkvtecsi99
Thanks for the reply. I already have the VAFC and plan on installing that at the same time. My reasoning for wanting the springs and retainers is because in the event that I up the cams to something more aggressive than the ctr/itr, I will already have the valvetrain stuff out of the way.
