Ls/vtec
Old Nov 9, 2002 | 03:39 PM
RHYMESAYER's Avatar
RHYMESAYER
Default Ls/vtec
can you guys help me out by listing some of the pros and cons of ls/vtec
Old Nov 9, 2002 | 03:51 PM
EX R8ED's Avatar
EX R8ED
is whipped
Bottom line...don't be cheap. Check out www.c-speedracing.com
Paulll's Avatar
Paulll
Hail Bent
Pros: Great for Turbo
Cons : $$$$
Old Nov 9, 2002 | 04:01 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Uh, an LS/VTEC setup isn't necessary "good for turbo." It depends on how you build it. The main problems associated with putting a VTEC h ead on a non-VTEC block come from the lack of a block girdle and VTEC oiling components. Granted, those can be added to a non-VTEC block, but they require a good amount of work and know-how in order to be done properly. If you want the strengths of an LS/VTEC setup, without the reliability issues, just get a GSR swap and put an LS crank and rods in it. You'll gain the LS stroke and torque while retaining the GSR girdle, oiling components, and reliability.
Old Nov 9, 2002 | 04:02 PM
Paulll's Avatar
Paulll
Hail Bent
I thought that they were great because of low compress ratio.
Old Nov 9, 2002 | 04:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
A p72 head on an LS block will yield a 9.7:1 c/r with stock LS pistons. While that c/r can be easily boosted, "good for turbo" is too broad a generalization to make in regards to an LS/VTEC.
Old Nov 9, 2002 | 04:26 PM
Paulll's Avatar
Paulll
Hail Bent
:jawdrop: :bowdown: u know ur engine codes and whatnot
Old Nov 9, 2002 | 05:25 PM
whiteEJ8's Avatar
whiteEJ8
http://www.hondalife.com/articles/lsvtechype.htm
Old Nov 9, 2002 | 08:10 PM
RHYMESAYER's Avatar
RHYMESAYER
i heard you have told plug some holes or something???? thats why people say "it's good if its done right"?
Old Nov 9, 2002 | 08:23 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You have to plug the VTEC oil orifice on the head. What people mean by "doing it right" is the use of VTEC oiling components and not just slapping a VTEC head on a B18A/B block. Also, if you opt to use a block girdle, it must be doweled in place, and not just bolted on. If you try to half-ass it and just bolt it on, you'll be doing more harm than good.
This is the right way to install a block girdle on a non-VTEC block:
http://honda-tech.com/zerothread?id=263598
As you can see, it's a fairly involved process, and unless you have some machining skills, it'll cost a lot in labor to have it done properly. That's why I suggest running a GSR block with an LS crank and rods, rather than putting a VTEC head on an LS block.
