fixing hydrolock
Old Nov 8, 2002 | 05:57 PM
Solaufein's Avatar
Solaufein
Default fixing hydrolock
I hydrolocked today after getting a flat tire. Bad car day.
Anyway, to get the water out of the engine, do I just pull the spark plugs out and crank the engine until the water comes out? Is there anything else to it? I do plan on changing the oil too.
Old Nov 8, 2002 | 06:04 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
A syringe + tubing to suck it out? :dunno: You could always flip the car on it's roof! :thumbup:
Old Nov 8, 2002 | 06:18 PM
b00gers's Avatar
b00gers
i pulled the plugs and cranked it while at WOT, then my car came back to life.
:whew:
you can try that.
Old Nov 8, 2002 | 06:22 PM
KillerB17's Avatar
KillerB17
We saved a 00 Si at the Honda dealer I worked at by pulling the plugs and cranking it for a long time. When the car did start a lot more water came out of the exhaust to. Even though it ran fine the mechanic said that it still put a lot of wear on the motor. Also change the oil IMMEDIATELY, it will look like muddy oil when it comes out.
Old Nov 8, 2002 | 06:49 PM
b00gers's Avatar
b00gers
im changing it in the morning....i went about 10 miles on it though.
Old Nov 8, 2002 | 08:03 PM
Solaufein's Avatar
Solaufein
What is WOT?
Old Nov 8, 2002 | 08:32 PM
b00gers's Avatar
b00gers
wide open throttle. when the accelorator is to the floor. when you floor it.
Old Jul 12, 2010 | 08:01 PM
DelSol1967's Avatar
DelSol1967
Default Del Sol Hydrolock! Need Help!
I found alot of water in the first 2 cylinders closest to the front of the engine. I got it out. It has been 2 days drying out and I put a bit of Marvel mystery oil in the cylinders to see if it would break lose. So far I have tried to turn it over and it does not move. Should I try to pop the starter continously? Is there a way to turn the crank manually? I cannot see how to get a socket in there.
