Skunk 2 Rear Lower Arm Bar?
Old Nov 8, 2002 | 07:49 AM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Default Skunk 2 Rear Lower Arm Bar?
This is a lower tie bar correct? Anyone have it on their car? Likes or dislikes?
Old Nov 8, 2002 | 08:04 AM
ManTiS's Avatar
ManTiS
NinJA
A tie bar looks cool.
Old Nov 8, 2002 | 08:39 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
and thats about it.
I've heard many people say that the didn't feel a damn difference when adding a tie bar.
Old Nov 8, 2002 | 08:59 AM
whiteEJ8's Avatar
whiteEJ8
I thought the rear tie bar actually did something. I thought it was the rear strut bar that was worthless. I don't have either so I wouldn't know but thats just what I heard from several sources.
Old Nov 8, 2002 | 10:52 AM
ManTiS's Avatar
ManTiS
NinJA
It's all in their heads. They do something it's just minimal.
Rear anti-roll bar :thumbup:
Old Nov 8, 2002 | 12:00 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Mr. Charlie Grifter has a Skunk, I believe. They serve a function, which is to limit flexing of the subframe, which tightens up the overall feel of the car and makes it a bit more responsive. If you already have a good amount of suspension mods like higher rate springs, stiffer dampers, etc, you're probably not going to feel the difference with a lower tie bar. People throw them on expecting a night/day change in handling characteristics, and then say they're useless because they didn't "feel" a difference. Also, if you have a larger rear swaybar(cough cough ITR, etc) on a Civic, it has a decent chance of tearing out of the relatively weak subframe. A lower tie bar will help support the subframe and keep it from flexing, which will lessen the chance of tearout(it might still happen).
Old Nov 8, 2002 | 05:41 PM
Outxider's Avatar
Outxider
X-Motoring
i got a skunk2 lower tie bar. as far as suspension, i got:
gsr skunk2 rate coilovers
koni yellows
gsr upper strut bar
skunk2 lower rear tie bar
oem front sway bar
i dont have a rear sway at all, but from ridin around in this setup, the response is great, so imagine if i get the upper rear strut and a rear sway. im happy with it.
late
