error code on my civic. HELP!!!!
Old Nov 6, 2002 | 10:51 AM
madcow's Avatar
madcow
Default error code on my civic. HELP!!!!
my engine light flashes 9 time fast, then it does 2 long flashes followed by 2 short flashes. it pauses and does it all over again.
i cant figure out what code that is. its confusing me.
http://members.tripod.com/csharkey98/ECU_Codes.htm
are those codes correct? what code is my civic throwing? help me please!
Old Nov 6, 2002 | 11:01 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
That would be a 9, and a 22.
9 CYP Sensor (Cylinder)
defective circuit or unplugged / defective sensor
22 VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
Old Nov 6, 2002 | 11:24 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
when its sensor based i always start by resetting the ECU to see if it will happen again, cuz usually it doesnt.
Old Nov 7, 2002 | 08:45 AM
madcow's Avatar
madcow
i think there is a real problem cause my car looses power and stutters alot...
think resetting the ecu will FIX it?
what do i do to fix the cyl pres? valve job? where should i take it? how much?
oil pres switch? eek, what do i do.. im screwed...
i need a damn b18 and my worries would be over eh?? =)
Old Nov 7, 2002 | 08:48 AM
crucial Si's Avatar
crucial Si
Banned
i can help you w/ 22,
take the ground wire from it and have it going directly to the battery ( - ) that would complete the circuit and it would make your vtec crossover, but the vops itself at honda is $55.
Old Nov 7, 2002 | 08:53 AM
madcow's Avatar
madcow
is that a good idea?
Old Nov 7, 2002 | 08:54 AM
crucial Si's Avatar
crucial Si
Banned
sure you can do it for a while...just until you have enough money to get it from honda...
Old Nov 7, 2002 | 12:00 PM
madcow's Avatar
madcow
honda parts department and all their infinate knowledge told me that there is no such thing as a CYL Pressure Sensor and its really a crank position sensor... and to fix BOTH errors that i needed a new distributor...
wtf... is that right?
Old Nov 7, 2002 | 01:12 PM
crucial Si's Avatar
crucial Si
Banned
you dont need a fawking dist. your ecu wont let you know if that goes bad.
Old Nov 7, 2002 | 04:06 PM
96extec's Avatar
96extec
You just need a cps sensor not a dist. their brain dead
