Header question
Old Oct 27, 2002 | 07:49 PM
Hondaman's Avatar
Hondaman
Black Pearl
Default Header question
On a 96 Civic LX, what happens to the cat. conv. when you put on a set of headers? Is it totally eliminated? If so, where do the two O2 sensors go? Anyone have an pics?
Thanks,
Tom
Old Oct 27, 2002 | 08:58 PM
Nelson's Avatar
Nelson
Administrator
It's not eliminated.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 27, 2002 | 09:02 PM
madtownhonda's Avatar
madtownhonda
Get an EX header, cat and exhaust. Everything will bolt up. Otherwise you can use an EX header w/ a stock exhaust but the cat will be eliminated.
Old Oct 27, 2002 | 09:08 PM
Nelson's Avatar
Nelson
Administrator
:eh: ? This some kind of 6th gen problem?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 27, 2002 | 09:17 PM
DSC's Avatar
DSC
Long way from home
The LX cat is directly after the exhaust manifold. So if you got a EX header, you'd need to get rid of the cat to make it fit.
Old Nov 24, 2002 | 11:53 AM
Hondaman's Avatar
Hondaman
Black Pearl
I don't think I ever really got an answer on this. The original header and cat are one piece on this engine. There is one O2 sensor before the cat and one after the cat. What happens to these sensors and how would the second one read with no cat on the engine. I would think it would cause the SES light to come on. Is the cat just eliminated like stated above or would I use a different setup for the exaust and have a removable cat below the engine or under the car instead of in the engine bay?
Thanks.
Tom
http://www.hondaautomotiveparts.com/...NIFOLD+%281%29
Old Nov 24, 2002 | 11:56 AM
96extec's Avatar
96extec
The o2 sensors will bolt right back up,if you get your stock headder,your cat will stay but if you go to a ex headder i dont know.
Old Nov 24, 2002 | 02:47 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Thanks.
Tom
If you get an EX header, cat, exhaust, your two O2's will be retained. One goes in the EX heater, the oth goes in the EX cat. The second O2 is basically there to determine whether the cat is in good working order or not, so if it sniffs excess emissions, it'll assume the cat is bad and throw a code. Some have merely taped the second O2 up out of the way and had no problems, but there's no need to do that if you run a complete EX header/cat/exhaust setup. If you run an EX header and do not switch to an EX cat and exhaust, the EX header will bolt directly to the LX exhaust without a cat, and without a place to put the second O2.
Old Nov 24, 2002 | 03:06 PM
Hondaman's Avatar
Hondaman
Black Pearl
-edit-
Ok, I think it was answered above, Thanks again,
Tom
