RH CV axle not clicking into position
Old Mar 17, 2008 | 11:34 AM
boatwire's Avatar
boatwire
Default RH CV axle not clicking into position
Ok, so I took the axle back out (it pulled right out, no prying needed) and took some measurements...dimensions show it appears to be the correct axle. Problem: cannot get the retaining ring past the first set of splines...I'm hearing a fairly solid metal to metal sound when I try to slide it home all the way.....still not locking in place. A little help from a sledge maybe? Anyone else encounter any difficulty w/replacing CV axles on 92 Civic 5 spd?
Old Mar 17, 2008 | 12:36 PM
qtiger's Avatar
qtiger
It's that little metal ring (The real name escapes me atm) on the end of the axle that's your problem. Get a new one or pinch the old one closed/tight with a pair of pliers.
Old Mar 17, 2008 | 03:51 PM
boatwire's Avatar
boatwire
it just took a bigger hammer.....but thanks.
now, if my Left Upper Control Arm would get here, I could be driving again.
