GSR Rear brake conv/Poly bushings??
Old Oct 21, 2002 | 03:07 AM
wilsel's Avatar
wilsel
Default GSR Rear brake conv/Poly bushings??
If I want polyurethane bushings for a 95 Civic EX coupe with a GSR rear disc swap will the integra bushings work for the front?
Or do I need civic bushings for the front, and teg bushings for the back??
Old Oct 21, 2002 | 05:10 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
When i ordered my ES master bushing kit, i talked to the shop owner for about 20 minutes about all kinds of things... of of them was that the front bushings are the same between civic and teg, and that the rear ones are different. You will need to order a teg kit, and that will work fine, except for a few odditied like shifter bushings, unless you have an engine swap.
Old Oct 21, 2002 | 06:06 AM
wilsel's Avatar
wilsel
Hey, thanks a lot camo! Is the squeaking that bad? Are the bushings worth it in your opinion?
Old Oct 21, 2002 | 06:51 AM
white lightnin's Avatar
white lightnin
When I did my full kit I asked for a teg kit. ANd within the package some of the piees said civic on them. I think they are pretty interchangeable. I hope you have fun installing it.
Old Oct 21, 2002 | 07:39 AM
dnt94civic's Avatar
dnt94civic
only get the rear teg bushings if you changed the rear lca's too.
If you kept your stock rear lca's, then just get the civic bushings all around.
Old Oct 21, 2002 | 08:20 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
DOH!
thats true. I forgot to mention that h:
Old Oct 21, 2002 | 08:21 AM
randomtask77's Avatar
randomtask77
Wanderer
How much do the bushings go for (just for the rear LCA's for the teggy)? Might as well replace mine when I do the swap.
Old Oct 21, 2002 | 08:23 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
i havn't had a chance to install them yet, but i got the graphite impregnated bushings which are supposed to be 'self lubricating' and shouldn't sqeak.
for JUST the rear LCA's? No idea, call up a place that carries them. Shouldn't be too much, maybe $15-40? guestimate
Old Oct 21, 2002 | 08:34 AM
wilsel's Avatar
wilsel
Okay, while I'm doing it I plan on getting the teg LCA's so I can add the ITR sway bar in the future. Thanks for the info!
