trouble starting my sol
Old Feb 10, 2008 | 09:00 PM
fast del sol's Avatar
fast del sol
Default trouble starting my sol
my sol wont start. ive tried a new main relay and checked all the fuses. my fuel pump doesnt turn on when i turn the key foward. i dont know what else to do someone please help
Old Feb 11, 2008 | 05:22 AM
Line7's Avatar
Line7
Platinum Member
well its obvious you need a new fuel pump.
Old Feb 11, 2008 | 05:57 AM
Running925's Avatar
Running925
Your Powder Coater
check main relay.. check ecu fuse.. if that failes.. try to jump your fuel pump to see if it will prime or not.. if it doesn't then u'r pump took a shit.
Old Feb 11, 2008 | 07:48 PM
fast del sol
ok ive already direct wired the fuel pump and it kicks on. im also not getting any spark i believe. will the ignition module have anything to do with both not working?
Old Feb 11, 2008 | 11:14 PM
Chris_Baker86's Avatar
Chris_Baker86
Sure its not your main relay, sounds like the same problem I had & thats what was wrong with mine...
Old Feb 21, 2008 | 09:04 PM
fast del sol
i went thru five different main relays
Old Feb 23, 2008 | 05:58 AM
spoon-eg-'s Avatar
spoon-eg-
get a test light and unplug the fuel pump and check if your gettin power to it. if you are then its the fuel pump.check the grounds on the engine also. just something i would do
Old Mar 6, 2008 | 05:55 PM
fast del sol
ok i found da fuel problem, now it still still wont start. ive tried a new distirbutor and computer, plugs, cap, rotor button and it still wont fire. does anybody think it can be a timing problem or what?
Old Mar 8, 2008 | 01:24 AM
A-series's Avatar
A-series
v-card member alpha
Assuming you tried a new ignitor/ignition module when you tried the new distributor, did you check for power at the wires that attach to the ignitor?
Old Mar 9, 2008 | 07:45 AM
fast del sol
i feel really stupid now. the wires on the distributor were wrong but now its runnin a lil rough so im gonna play wit the distributor change the wires and stuff cuz its been sittin a while. i dont have any vacuum leaksso imma try dath:
