Powder Coating: first try
Old Feb 5, 2008 | 02:53 PM
fathergoat's Avatar
fathergoat
Default Powder Coating: first try
I'd been kicking around the idea of powder coating for over a year. The problem was I just want to do it for fun for myself so I didn't want to spend much. Well recently I had the opportunity to get an electric stove for free from a friend. So I made a little trip to Harbor Freight and bought a cheap powder coating kit. I picked up some powder local at pendry (www.pendrypowdercoatings.com). Here is what I ended up with on my first try.
I tried for a 2 tone. But I think I forgot to clean around the "H" so it bubbled up and didn't adhere well.
The other problem I had was the instructions said working pressure of 10-30psi. Basically at 20psi it comes out like a fire hose. I found that it really worked best around 6psi. As a result of my tinkering I didn't get the best coverage in spots.
This was a spare valve cover I had laying around and decided to practice on. I plan on doing the one on my car in flat black with a red "H". All in all I'm relatively pleased. I figured out how to get everything to work pretty good and I think I can do a good job on the next one.
Old Feb 5, 2008 | 03:27 PM
Fuse's Avatar
Fuse
cool. Looks good
Old Feb 5, 2008 | 03:37 PM
nightmareivc's Avatar
nightmareivc
not bad next time try to do a more even coat by just staying at a constant distance and slow back and forth motion
Old Feb 11, 2008 | 07:05 AM
gsrsol's Avatar
gsrsol
slow and low
yeah and your over lap on the writing can be sanded and buffed. that will make a little more of a difference.
Old Feb 11, 2008 | 05:50 PM
honura's Avatar
honura
Seni
Not bad for your first time. You will get better as you do more stuff.
Old Feb 11, 2008 | 06:58 PM
Running925's Avatar
Running925
Your Powder Coater
Ehh not to bad.. definatly need to get control of your flow & make sure to get even coverage. The item HAS to be media blasted to get a strong coating. Also, Make sure your electrode is not caked up when spraying.
Soon your resultz will look like mine!
Old Feb 11, 2008 | 07:20 PM
lkailburn's Avatar
lkailburn
college kid
how are you guys running your regulator system. i've got a similar problem of keeping a good constant psi.
-Luke
Old Feb 11, 2008 | 07:44 PM
Running925's Avatar
Running925
Your Powder Coater
compressor, half in. lines, reg. mounted on wall, half in. lines. gun.
Old Feb 11, 2008 | 10:27 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Way tah go Goat!!! :cheers:
When I have a garage, I plan to give that a shot.
Old Feb 11, 2008 | 11:13 PM
Chris_Baker86's Avatar
Chris_Baker86
I almost ordered a kit the other day. I plan on giving it a shot here soon as well...
