Rear Brake Conversion
Old Oct 20, 2002 | 02:16 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Nah its should just bolt on, just on teh Prop Vavle be carefull not to kink the lines when u switch them.
Old Oct 20, 2002 | 02:19 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
kink the lines? u mean strip it or???
also, what is the difference between civic EX brakes vs. the integra's brakes... cuz there is a guy that is selling the whole swap front and back as a set... so i don't know if upgrading the front will be more beneficial then what i have on now...
Old Oct 20, 2002 | 04:19 PM
undercover's Avatar
undercover
Here's exactly what you'll need:
- Rear trailing arms
- EBrake cables
- Master Cylinder
- Prop Valve
- Brake booster
Like someone else suggested, do the front too. I just finished doing this conversion and it is absolutely worth it. I also suggest maybe replacing your brake lines with stainless steel ones. You'll get a lot firmer brake pedal this way. It's nice. The front brakes are a little more trickier to do than the back so you might want to hold off on that until you get a good understanding of the brakes in the back. Expect your car on jackstands for at least a couple days if you've never done of these before. Most of your time is gonna probably be spent going back and forth to the part store. Just to save you some time, you're gonna need a flaring tool, a pipe cutter, a deep 12 socket, some of those wrenches for the brake lines (can't remember the name off top of my head), some cotter pins, a big ass breaker bar if you're doing the front axles, and I think that's it. Good luck.
Old Oct 20, 2002 | 05:51 PM
white lightnin's Avatar
white lightnin
ex front calipers are smaller.
Old Oct 20, 2002 | 06:20 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
says you.
Tell that to me.
I use integra pads in my EX.
I have a teg rear disk brake swap
(use the search feature for more answer btw)
Old Oct 20, 2002 | 06:39 PM
white lightnin
So you saying they are or arent smaller. I believe the piston is smaller. Doesnt mean pads wont swap out.
Old Oct 20, 2002 | 07:04 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
To the best of my knowledge, I beleive them to be the same size as the teg front calipers.
I have heard some discussion that the teg may be different, but I've never heard anything conclusive to contradict one or the other.
Caliper is the same size, piston size is a different story, not sure on that.
Old Oct 21, 2002 | 05:43 AM
madlow's Avatar
madlow
I have a 94 integra LS conversion 4-sale if you're interested. $375.00 or B/o. I just put it in the 4sale forum.
