EK Power Window Conversion Question???
Old Jan 26, 2008 | 04:33 AM
Luder916's Avatar
Luder916
Default EK Power Window Conversion Question???
I got a setup from an 00 HX into my 99 EK. I ran all the wires and added the relay plus fuses and everything works but the power lock. I was looking online and found that you need the Lock Box Controller (I think thats what its called). I went and got one but now when I try to hook it up to the door panel and the wires for the driver side door doesnt have a plug for it??? There is a wire to the power door lock actuator but no plug for the box???
My Question: Is there a differance from the wiring in the door panel on the driver side in the HX and EX??? Is the complete wiring different between the two? Can I just get a driver side wire system and hook it up and will it work?
Thanks ahead of time!
Old Mar 13, 2008 | 08:57 AM
NOOdS's Avatar
NOOdS
wussup homie...forget about the doors. lets go RIDE.
anyways, eh i got a reply for my power door conversion. i guess the 96-98 ek locks run off the fuse box. thats why it doesnt have the pulg for the control box. 99-00 ek locks run off the control box located in driver door. and somehow i think we might need to replace the lock acuators too. my parts are all mix matched...i should of just pulled everything off from the same car. i still think i dont have the right floor harness.
Old Mar 18, 2008 | 12:54 AM
jdmderick's Avatar
jdmderick
If not in the driver door the 96 VTI-R Honda (Jap spec) Australian delivered is under the steering colum.
Hope this helps
Jdmderick
Old Mar 19, 2008 | 07:41 PM
Luder916's Avatar
Luder916
Hope this helps
Jdmderick
Do you have a picture of where its located?
