Trouble starting car
Old Oct 17, 2002 | 10:21 AM
undercover's Avatar
undercover
Default Trouble starting car
I have a 95 Civic HB and just recently, I've been unable to start my car. I hadn't messed around with the car at all previous to this problem. It was functioning fine half an hour before and then all of a sudden this happens. When I turn the key, the battery is obviously charged, but I get no sounds of ignition, not even a little bit like its struggling. At first I thought it may have been my alarm which was causing the problem, but I disconnected my alarm from the battery and I still get nothing. Before I'm forced to get my car towed, are there any suggestions anyone might have?
Old Oct 17, 2002 | 10:34 AM
DB7 2.0's Avatar
DB7 2.0
Banned
no sounds at all????
is the engine turning??
Old Oct 17, 2002 | 10:44 AM
undercover's Avatar
undercover
Nope, besides my check engine light coming on and my radio receiving power, nothing happens at all.
Old Oct 17, 2002 | 11:07 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
How many miles on the car? If it is around 70k-100k...check your ignitor and coil.
Old Oct 17, 2002 | 11:26 AM
madlow's Avatar
madlow
your motor would still turn over just no spark to the plugs. It sounds like an electrical problem for sure.. All I can say is double check your alarm wires to make sure it's actually off.
Old Oct 17, 2002 | 11:34 AM
asiandoood's Avatar
asiandoood
h:... i missed that part.
Old Oct 17, 2002 | 11:36 AM
Tirod's Avatar
Tirod
what kind of an alarm?? it could have still cut your ignition wires, i had that problem.. i had to completey take out the brain and reconnect the ignition wires like they were before it was ever intalled..
Old Oct 17, 2002 | 11:40 AM
asiandoood's Avatar
asiandoood
what i do is take out the key...wait about a minute and try again.
Old Oct 17, 2002 | 11:47 AM
undercover's Avatar
undercover
It's a Clifford Cyber2. I disconnected the alarm from the battery and turned off the alarm backup battery. It shouldn't be influencing my car anymore should it?
Old Oct 17, 2002 | 12:07 PM
madlow's Avatar
madlow
hook it back up and see if it reset itself and alows you to start your car.
