turbo questions
Old Jan 15, 2008 | 08:55 PM
dspencer24's Avatar
dspencer24
b18c ftw
Default question
i got this turbo kit the guy said it will work on 92-00 civic sohc is there anything i need
Old Jan 15, 2008 | 08:58 PM
Snoopy's Avatar
Snoopy
been there done that
make sure the turbo's still good
Old Jan 15, 2008 | 09:21 PM
dspencer24's Avatar
dspencer24
b18c ftw
ok
Old Jan 15, 2008 | 09:31 PM
dspencer24's Avatar
dspencer24
b18c ftw
I'am i going to need fuel injectors?
Old Jan 15, 2008 | 10:56 PM
A-series's Avatar
A-series
v-card member alpha
Depends how much boost. I'm not sure how much is too much for the stock injectors, but they should be up to the job if it's relatively low psi. Might want to run some injector cleaner if it's been a while.
Old Jan 16, 2008 | 09:48 AM
Snoopy's Avatar
Snoopy
upgrading injectors is always a good idea. gives you room to grow in the future.
Old Jan 16, 2008 | 02:49 PM
dspencer24's Avatar
dspencer24
b18c ftw
anybody from northern ca put a turbo on before?
Old Jan 16, 2008 | 07:15 PM
dspencer24's Avatar
dspencer24
b18c ftw
well i called greddy and they said that it wont be able to work with me car! so its going in the classifieds
Old Jan 18, 2008 | 05:12 PM
2gr84u's Avatar
2gr84u
2gr84u
turbod16.com
homemadeturbo.com
go there and do some serius reading before you boost, trust me you want to know as much as possible about what your doing before you get started, you will save ALOT of money down the road and your car is gonna be better off if you know exactly what your doing. Even if your not installing the kit you should have an idea as to how everything works so you can tell when it isnt working right.
Old Jan 18, 2008 | 07:24 PM
dspencer24's Avatar
dspencer24
b18c ftw
thanks man im selling it anyways
