Trying to figure it all out!!!
Old Dec 1, 2007 | 07:55 PM
brian845's Avatar
brian845
Default Trying to figure it all out!!!
I've got a 95 ex coupe with a dead d16z6 and second gear isnt there any more. Im planning to replace it with a b16 motor and tranny. I've got a good bit of info so far still a little unsure? can I use the mounts I have or do I need to get new ones from hasport. The only other thing is the wiring for the knock sensor? I cant find an ecu drawing, and do I need to use the one from the b16 or can I use the one from my Ex might sound stupid to you but I duno?
Old Dec 2, 2007 | 03:30 AM
mini-me civic's Avatar
mini-me civic
if the b16 is an obd1 motor you can use the original engine harness, as far as knock sensor, use the p28 ecu.. that ecu eliminates the use of a knock sensor.. other than that everything else is plug n play..
Old Dec 2, 2007 | 04:42 AM
brian845's Avatar
brian845
ok thats good how do I get my hands on the p28 ecu is that the one from my ex?
Old Dec 2, 2007 | 06:40 AM
fathergoat's Avatar
fathergoat
:3
yes, you should have a P28 already. You might need to chip it to run a B16 map. I haven't done a swap so I'm not sure. Check the swap section, it should contain all the info you need. https://www.honda-acura.net/forums/f...splay.php?f=33
Old Dec 2, 2007 | 01:04 PM
mini-me civic
a stock p28 unchipped should run a b16 with no problems..
Old Dec 2, 2007 | 05:03 PM
brian845's Avatar
brian845
I appreciate you guys help Ill let you know how it all turns out
Old Dec 4, 2007 | 09:34 PM
jasony0630's Avatar
jasony0630
since your civic's pre obd2, just go b16a3 for the hydro tranny...thats what i say. oh yeah, if anyone is confused about the little controversy about the b16a3 being obd2, its obd1. thats where my civic is going....tomorrow, getting a b16a3, except youre a little luckier than i am...my car's an obd2 civic ex ('99) so dont be stupid like me
