whats best to work?
Old Nov 18, 2007 | 08:09 AM
i.got2!'s Avatar
i.got2!
Default whats best to work?
hey whats up!! , i have a GSR im getting type r suspention on it, so i was thinking about putting my old GSR suspention on my 93 civic which it already has rear disk brakes.... i was thinking more like for the front suspention OR ARE THEY THE SAME(GSR FRONT SUSPENTION & (93 Civic FRONT SUSPENTION)
Old Nov 18, 2007 | 09:24 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Suspension......
I think the GSR front a rear discs are slightly larger in diameter than the OEM Civic ones.
Old Nov 18, 2007 | 10:26 AM
i.got2!'s Avatar
i.got2!
Are the break caliper bigger also or the same
Old Nov 18, 2007 | 10:34 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
They're bigger and different looking.
Please learn grammar.
Old Nov 18, 2007 | 11:53 AM
i.got2!'s Avatar
i.got2!
Its my LA Slang HOMIE!! IN the GOOD WAY
Old Nov 18, 2007 | 11:59 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:shake: Not when we can barely understand you.
Since your Civic already has rear disk brakes, there's almost nothing to swap from your GSR that is worth your time.
The rear sway bar from your GSR would be a nice upgrade, but leave the brakes alone unless you plan to take the master cylinder out of the GSR as well.
Moved to Civic / Del Sol / EL
Old Nov 18, 2007 | 12:27 PM
qtiger's Avatar
qtiger
I've done a complete GSR suspension swap onto a 94 civic. The civic will ride very high if you put the GSR struts and springs on it. Like... 4 wheeling high.
Old Nov 18, 2007 | 02:27 PM
i.got2!'s Avatar
i.got2!
For ((the other dave)) you think I should leave the front suspention on the civic instead of the GSR Front suspention??? What would you do? Would you leave it or swap it?
Old Nov 18, 2007 | 02:47 PM
TheOtherDave™
Apathy Kills
By suspension, which parts are you referring to?
The control arms, shocks and springs aren't worth the effort of swapping.
Plus, your Civic will be lifted if you use the springs off of your GSR.
The only part I'd suggest swapping would be the rear sway bar.
Old Nov 18, 2007 | 03:15 PM
i.got2!'s Avatar
i.got2!
Sorry for the I meant the spindle
