Fuel gauge problem??
Old Nov 9, 2007 | 08:47 AM
civic8891's Avatar
civic8891
Default Fuel gauge problem??
I having a problem with my fuel gauge. The gauge will be like at half a tank and then go up to full and stay that way. A little later it will go all the way to empty while I have a half a tank or so. I checked the float and it looks ok. What else could this be? Do Honda's have a sending unit? Could this be it? Where is the sending unit? Any ideas would be appreciated.
Old Nov 9, 2007 | 11:59 PM
A-series's Avatar
A-series
v-card member alpha
I believe the sending unit is located right by the fuel pump itself, under the access panel. That's where it's at on 5th gens at least.
You're supposed to use a special wrench or something to remove it, never done it myself so not sure if it's really necessary, just fyi.
There should be a fuse, 10a I think, in the under-dash fuse box that you should check first. You'd think it wouldn't work at all if it was the fuse, but people on here have experienced some weird stuff that turned out just to be a fuse :hsdunno:
