Temperature sensor
Old Oct 11, 2007 | 09:48 AM
randomtask77's Avatar
randomtask77
Wanderer
Default Temperature sensor
After replacing what I thought was everything that has to do with the cooling system, I recently found out that there is another sensor that is below the distributor (93 civic coupe with D15).
Would this sensor have anything to do with my temp gauge not moving?
I know the temp gauge works (it has shot up before when my car did overheat), and I've replaced all the fuses and sensors associated with it (except the one mentioned above) but would just like opinions if anybody knoew if this has anything to do with the temp gauge not going to the halfway mark during normal everyday driving.
Old Oct 11, 2007 | 10:38 AM
finnstang's Avatar
finnstang
The sensor for the temp sending unit is a one wire sensor underneath the distributor.
Old Oct 11, 2007 | 10:59 PM
A-series's Avatar
A-series
v-card member alpha
Where does the needle get to?
I don't know the specifics of the temp gauge sensor but I know that the thermoswitch (turns cooling fan on) can get progressively bad, so instead of just not working all of a sudden, it will take longer (more heat) for the fan to turn on over time. Maybe that sensor is still working but doesn't have the sensitivity it did when new.
Regardless, the thermoswitch and the sensor that reads the temp for the ECU are most important. As long as the thermostat opens and there's coolant in the radiator. (no heat w/out both)
I'm sure you already know most or all of that, randomtask77, meant more for others.
Old Oct 12, 2007 | 12:07 AM
randomtask77
Wanderer
The needle doesn't move at all. If I'm stuck at traffic and have been driving for a while, I'll see the temp gauge move up ever so slightly to the "C" mark, but no further.
The first thing I did was switch out the thermoswitch (the one that is near the thermostat). Then I eventually changed out everything else. Radiator, the fan, radiator cap, thermostat, both upper and lower hoses and clamps. The fuse to the fan that is under the hood. The fuse that is under the dash and obviously the coolant. The only thing that I didn't get to replace was the sensor that is below the distributor (which I didn't know about til recently).
I thought I had a thermostat stuck open until I replaced that as well and I was still getting the same result.
Old Oct 12, 2007 | 01:38 AM
A-series's Avatar
A-series
v-card member alpha
Alright, here goes...
What you'll see looking at it from the front of the car:
This is what you'll see if you stick your face down there for a better look:
This is with the camera phone all up in there:
The Coolant Temp. Sending Unit should be torqued down to 7ft-lbs. (or tight, but not too tight, with a ratchet as I would do it) and you should use liquid gasket on the threads.
It's not that uncommon for people to mistake the TW Sensor (not switch as I labeled it in one pic) for the Temp. Gauge Sender. Unrelated to your Q but incase someone's wondering, the TW Sensor should be torqued to 13ft-lbs. whereas the Thermoswitch, even though they look alike, should be about 17ft-lbs.
This should apply to all 5th gen ('92-'95) Civics. The pics are from my USDM '92 EX.
Hope that helps.
File Type: jpg
