car starting problems
Old Sep 4, 2007 | 05:20 PM
Bad_Religion's Avatar
Bad_Religion
Default car starting problems
ok well i was messing around and i found a throttle body spacer and i wanted to put it on not for the power just for the color under the hood, ok put it on car started.next i put my aem intake on and i was gonna test drive it and the car wouldnt start.i turned the key and turned it and smoke came out of the intake smelled like gas.ok well it finally started and i drove it and the car ran really nice by the way its a 93 civic. well parked it checked in within the next hr or to and it wouldnt start again.well ok i said fuck it took the throttle body spacer off threw it away.put eveything back and car still wouldnt start.well after messing with everything checking spark fuel pump it would start but sound flooded out.let it sit cleaned spark plugs off and next morning. checked distributor everything good checked battery everything good. well finally started sounded nice and ran nice. let it sit 2hrs or so wouldnt start again. its like its not getting a spark somewhere sprak plugs and wires are sparking.some one said coil. i started car and wiggled the key back and forth and it didnt die out. we cant think of what to check.its not even throwing a cel..this car ran perfect till now..please help me out..i tryed to explain everything good as i could.
Old Sep 4, 2007 | 08:11 PM
Fuse's Avatar
Fuse
Did you use new gaskets on the throttle body? You might have created and intake leak. Some intake leaks (gasket related) leak cold. Heat applied to some thing make is expand. Letting something cool off contracts and object.
What plugs are you using. I have a hard time re using flooded out plugs in less i clean them with this http://www.jcwhitney.com/webapp/wcs/...atalogId=10101 Mini sand blaster.
http://www.spark-plugs.co.uk/pages/t.../diagnosis.htm 2nd one down is covered in carbon. Carbon is a better conductor of electricity then air so the spark never jumps the gap.
Old Sep 5, 2007 | 03:56 AM
Bad_Religion
the gasket on the throttle body broke so we put some kind of gasket stuff out of a tube on there untill i can find one advanced auto said they dont have anything or see gaskets in there computer spark plugs are bosh or something like that
Old Sep 5, 2007 | 07:41 AM
Wharbone's Avatar
Wharbone
Paragraph
par·a·graph (pr-grf)n.
1. A distinct division of written or printed matter that begins on a new, usually indented line, consists of one or more sentences, and typically deals with a single thought or topic or quotes one speaker's continuous words.
2. A mark ( ¶ ) used to indicate where a new paragraph should begin or to serve as a reference mark.
3. A brief article, notice, or announcement, as in a newspaper.
tr.v. par·a·graphed, par·a·graph·ing, par·a·graphs To divide or arrange into paragraphs.
Old Sep 5, 2007 | 04:46 PM
Bad_Religion
update on the car. well what we did was put the tbs back on because it had to gaskets sinve the throttle body on broke. the car started up after we did that and it idled really high then go low then high then low doing it pretty quick. well we pulled the vacum hose to the fuel filter relay the the vacum on top the the throttle body and it idle stoped and it idle alirght but not normal like it should. ok we put the hose back on then it did the idle high and low again so i took it for a ride i drove it ran good drove good but when u let go of the gas it would idle the high and low stuff again.we really dont no what to do, maybe the ecu isnt reading the tbs right, the distributor, were thinking its not getting a spark some where i dont no, i ordered the throttle body gasket comes thursday, i really need this car going again im having trouble getting home and to work lol.
Old Sep 6, 2007 | 06:32 PM
Fuse's Avatar
Fuse
Fluctuating idle is a good sine of a vac leak. Probably just the gasket.
TBS?
Old Sep 7, 2007 | 07:34 AM
Bad_Religion
i got it, thanx for all your help man. it was the tps
Old Jun 5, 2008 | 12:22 PM
nimitz's Avatar
nimitz
yeah if the throttle body spacer is not machined for that application and is only universal, it will block the air flow to the manifold at idle making it idle low when you put it in gear. you would have to take the tbs you purchased to a machine shop to open it up on the edges so it dosen't restrict the airflow at idle.
