Noone's perfect, esp. when it's late.
To show you what I know, I wish mine switched the exhaust instead of the intake (changing plugs would suck ass though) and I don't even know if that make sense, or would work :oh: |
Originally Posted by sherwood
(Post 3613182)
You're on crack, I have never heard of a mechanical VTEC failure in my LIFE.
The reliability of the VTEC system is not the limiting factor for either. non-vtec: less moving parts easier to tune vtec: eats oil (ok, a slight exaggeration...) Plus, you can run a bigger cam in a non-vtec head :p Overall, this is an irrelevant debate. This is like arguing which would make a stronger letter opener, stainless steel or an aluminum alloy. VTEC is a great technology. There's no debating that. Also, what's wrong with 5th gen transmissions? Or are you just referring to autos? |
Originally Posted by ddd4114
(Post 3614376)
Originally Posted by Snoopy
(Post 3614701)
and have a shitty idle. run that same profile on a vtec cam and you can have a smaller primary.
:p <<< means I didn't mean for you to take the comment that seriously
I know the point of VTEC, and as I already stated:
Overall, this is an irrelevant debate. [...] VTEC is a great technology. There's no debating that.
is vtec the only dohc motor or is there other dohc motors or should i just get a sohc motor?
Originally Posted by bighroder
(Post 3614795)
These engines are smooth, potent, and above all just fun. Their featured models also generally sport the highest technologies available from Honda at that given time, so they are really great cars. The SOHC VTEC designs usually showcase an improved torque band over the same rev range, or better gas mileage in the same rev range as their non-VTEC counterparts. BUT this all really depends on what you want in a car, if you give us a better description of what you're looking for we will probably be able to point you in the right direction, whether the car be a Honda or not. |
if you're still confused about what vtec is, here:
http://auto.howstuffworks.com/question229.htm http://www.youtube.com/watch?v=AcT_ZyY3F0k |
I dont understand one thing. (Just thinking aloud here) How can a SOHC vtec only adjust the exhaust lobes? Intake and exhaust ride on both outer lobes, when vtec "kicks in" the solenoid opens alowing oil pressure to lock pins in the rocker arm thingies which locks the outter rockers riding on the outer lobes for each cylindar to the inner arms which ride the inner lobe which has a higher lift profile. This in my theory would mean that both intake and ehaust recieve the exact same added lift/duration. Even the diagram from howstuff works theoretically suports my theory. Is there any facts about how vtec can only engauge on the exhaust (i heard intake sometimes too) side.
I dunno, but im still thinking about this one... |
Originally Posted by Kabooki
(Post 3614857)
I dunno, but im still thinking about this one... The reason is because the spark plug holes rest between the exhaust valves, preventing an extra rocker arm from being added in that location. |
