95 del sol - dies when i come to a stop-
Old Aug 26, 2007 | 11:11 AM
jessec's Avatar
jessec
Default 95 del sol - dies when i come to a stop-
ok..I had this problem when i got the car (when i come to a stop the rpm's drop off and it dies) it an automatic 1.6 vtech sohc.. I replaced the coil... dis.cap and rotor and plug and wires and put some injector cleaner in the tank, and its still doing it.. i'm gonna try the fuel filter but I don't really think its that for some reason... and there isn't a engine light on --- maybe the ICM ???
Old Aug 26, 2007 | 11:14 AM
IgOtNOluCk's Avatar
IgOtNOluCk
New on the import scene
does it do it when its cold?
Old Aug 26, 2007 | 11:22 AM
jessec's Avatar
jessec
I think mostly when its warmed up
Old Aug 26, 2007 | 12:02 PM
IgOtNOluCk's Avatar
IgOtNOluCk
that is the idle air control valve . . .
Old Aug 29, 2007 | 09:19 AM
champneys05's Avatar
champneys05
if all else fails temporarily set your idle higher, it always works.
Old Aug 29, 2007 | 09:01 PM
A-series's Avatar
A-series
v-card member alpha
That will do the job of course but since it's an auto you'd be better off just braking with your left foot while giving the car a little gas as you roll to a stop - as a temporary fix that is.
It's a good idea to change the fuel filter anyway but I don't think that will fix the problem either.
Does it start up normal and idle fine if it's in neutral?
Try getting the engine revs up and then quickly off the throttle in neutral when it's all warmed up and see if it dies then - if so I'd assume you need to adjust the IACV as IgOtNOluCk said.
Old Sep 2, 2007 | 04:14 AM
jessec's Avatar
jessec
it does run fine in neutral ...and coming off the highway to the stop sign after its warm is when it dies or idles low--ive been shifting back into neutral as i come to stops -- The iacv is adjustable??? i'm gonna pull it off today and clean it up and see if that helps
Old Sep 2, 2007 | 05:05 AM
A-series's Avatar
A-series
v-card member alpha
:chuckles: I dunno what happened there, I think either I confused the idle screw with the idle air control valve or had a brain fart and so told you to adjust instead of clean/replace. I don't quite remember now but you're correct, just clean it and then reattach it and the hoses once it's dry.
