Backseat removal....
Just wanted to get any heads up tips before I go breaking any clips or something like that. Just need a quick run down or how to for removing my backseat. What tricks or tools needed???
im not sure if it s the same on your car, but on my teg and friends civic, its held in with one bolt.
if you are looking at the backseats from the front, it should look like this....
_______________________
_________________*____
the top horizonal line is the top of the back rest, the middle horizontal line is there people lose their change, the bottom line is the edge of the seat. the* is the nut.
hope that helps
hope that helps
In my car you have to take the top and bottom apart in 2 difference pieces. For the top part it is 2 pieces, obviously. Push one piece as close to the center as you can, where it's hinge is closest to the outside of the car will be a clip thing that looks like a "C", pull it out, do the same for the other side. Now push the halves as far as you can to the ouside and pull them out. For the bottom seat there is one bolt which you should have exposed. Take that out then flip the seat up and pull it out.
