part numbers for 1993 civic ex
#25 is the bolt a - 18231-SR3-J01
#23 is the spring that surrounds tehe bolt - 18230-SA0-930
#32 is the nut - 90115-SB2-003
#22 is the gasket between the cat and the header - 18229-SH3-X30
#24 is the bolt b - 18231-SR3-A22
This may not help at all, but just in case, if you can't get ahold of the springs or if they cost a bit more than you'd like, I would try a lock washer (perhaps with several flat washers to get the right fit) to see if that did the trick :shrug:
edit: in hindsight, I'm not so sure that would cut it - it's possible that the springs serve more purpose than my first assumption but dunno :hsdunno:
I'd still try it though, but I'm cheap
