Help needed for Stoping AC leak
Hi,
I have 1993 Honda Civic LX (Sadan). The AC has started leaking all of a sudden. First I thought that I need to refill the R134. While recharging R134, I noticed that the green colored liquid is coming out of the pipe near the High end. After proper inspecting, I found that there is a leak in the join, where the pipe is joined to the base socket (Image attached).
Is there any way to stop this leak ?
Regards,
Sameer
Regards,
Sameer
Also I don't know if it has an accumulator or receiver dryer as I can't remember if it has TXV valve or Orifice tube.
if I remember correctly its a TXV and would have a dryer.
why would you need to replace the receiver dryer? If the system is properly evacuated/recovered than there is no need. Since you bring the temp up when you recover you boil out all the moister in the system.
opening a ac system makes the dryer susceptable to mositure, ruining the dryer, look it up any automotive text book will tell you to replace the dryer anytime you open the system, just a step to insure that you will not ruin the compressor of any other parts of the ac system, if you are just evacuating and recovering (not removing a line or a part from the system) no there is no need to.....
text book doesn't always equate to real life situations though. I have been working on A/C systems for quite some time and as long as I apply a vaccum to the system thus lowering the boiling point of the R134 than it will boil out the moisture from the system. I will agree it makes the dryer susceptable, but for the part he was replacing I wouldn't worry about it 9 times out 10.
