tranny fluid
Old Jun 4, 2007 | 12:24 PM
OurStory's Avatar
OurStory
Default tranny fluid
Hi,I recently got a swap and at first, it would shift really smooth and easy. Now now I notice the shifts are getting a little harsher and I feel a slight grind from 1-2. Could this be a sign that the tranny fluid is low ?
Old Jun 4, 2007 | 12:30 PM
Civic2Scooby's Avatar
Civic2Scooby
is it leaking?
if not check the level.
Old Jun 4, 2007 | 01:12 PM
94civicEX's Avatar
94civicEX
I got worms.
It's a sign that your synchros are biting the bucket, you should have flushed and refilled the tranny fluid when you got it.
Check your axle seals for leaks.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 4, 2007 | 05:37 PM
OurStory's Avatar
OurStory
I checked everything, there is no leak. But I think its grinding a little because my shift knob is kinda messed up. Like its not aligned with the shifter. I only started noticing this when I forced the shift knob back on..
Old Jun 4, 2007 | 07:40 PM
Civic2Scooby
that won't do it.
Old Jun 5, 2007 | 11:50 AM
94civicEX's Avatar
94civicEX
I got worms.
that won't do it.
Unless it's caused him to mishift...a lot, lol.
99 Integra GSR
06 TSX
Old Jun 5, 2007 | 12:15 PM
Running925's Avatar
Running925
Your Powder Coater
Running low on fluid in a honda usually effects 3rd / 4th/ before it effects the 1/2 combo.
I'm gonna say it's probably your synchros, you won't know until you pull it apart.
Old Jun 6, 2007 | 01:39 PM
OurStory's Avatar
OurStory
thats true but thanks for the help guys.
But an update, I replaced the shifter and everything is good. The shifter actually does cause alot of misshifts for me -_-!!
